Expression pedal Polarity
RichyeDoctrina
Hi everyone, i have a problem with the expression pedal
well the pedal turn on and changes between wah and volume, but nothing more, when you try to up and down the pedal (volumen or wah) isnt work
what can i do?
i don´t find a answer, i reseted a factory mode and still "polarity"
Puede ser una imagen de texto
Are you sure the Vol and Wah FX blocks Position parameter is properly assigned to the EXP1 and EXP2 pedal controllers? That’s the default but if those controller assignments have been changed it explains your symptoms.
