frstrat Posted January 12, 2025 Share Posted January 12, 2025 Hey all, I'm hearing some kind of artifact in my EV Panama Red and Blue presets. It's like there is a clean signal drowning out the saturated tone of the model. I've looked thru the setting and can't find what I've done wrong. In full disclosure, today is the first day I've listened to the preset via headphones. I've been playing thru my Gemini FRFR cab. Any advice is appreciated. Quote Link to comment Share on other sites More sharing options...
rd2rk Posted January 12, 2025 Share Posted January 12, 2025 Helps to know which device you're using - Helix, HXS or? How are you wired? If you attach an example preset it helps with troubleshooting. Quote Link to comment Share on other sites More sharing options...
frstrat Posted January 12, 2025 Author Share Posted January 12, 2025 Hi, sorry for the lack of detail. Hadn't needed to post in a while. I'm using Helix LT - guitar direct and using headphones out. I think I may have figured it out. I had the preset built with 4 snapshots and two amps (ev panama blue and a red) on a parallel path. Snaps 1 and 2 used the Blue while 3 and 4 used the Red. When I ditched either of the amp models the artifact (really a clean sound - just not sure what else to call it) resolved. Attached is the preset with both models. 5150 III .hlx Quote Link to comment Share on other sites More sharing options...
rd2rk Posted January 12, 2025 Share Posted January 12, 2025 Your Snapshot was disabling the unwanted amp, but not the signal path it was on. Try the attached mod. By changing the split to A/B and assigning the A/B Split to Snapshots, it switches the signal path. Note that it's no longer required to disable the unwanted amp. This practice can sometimes prevent unwanted "pops" when switching snapshots. 5150 III MOD.hlx 1 Quote Link to comment Share on other sites More sharing options...
frstrat Posted January 13, 2025 Author Share Posted January 13, 2025 I will take it for a spin. Thanks so much for the assist! Quote Link to comment Share on other sites More sharing options...
