herbalwharf9261 Posted January 28 Share Posted January 28 Tengo un problema al querer conectar la pod a la computadora. Para empezar, en el menu de mi pod me aparece que la version del firmware del usb es 0.00, vi que a otras personas se les soluciono calibrando las memorias flash y sdram, sin embargo eso no funciono en mi caso. Ya tengo instalados los drivers y el pod hd 500 edit, al intentar abrir este ultimo me dice que no detecta ninguna pod. Ya intente reiniciar la computadora, y le hice un reinicio de los ajustes generales a la pod, sin embargo esto tampoco funciono. El cable queda descartado como problema, ya que lo utilizo con mi impresora y funciona bien. Por otro lado, mi pc es un poco vieja por lo tanto no tiene entrada de usb 3.0 (que vi que puede ser un problema que causa que no detecte a la pedalera). Queria saber si tienen alguna idea de como puedo hacer para saber si acaso no funciona mi entrada usb, es un problema de la computadora o un tema de drivers Quote Link to comment Share on other sites More sharing options...
hurghanico Posted January 29 Share Posted January 29 The POD must be connected to USB 2.0, not to USB 3.0. It must also be connected to the main USB ports, not to port extensions such as USB HUB. Often the main and best USB ports are those closest to the power cable socket. I have 2 perfectly working PODs and both indicate USB FW:V0.00 on their display while they are disconnected, since they are connected and recognized by the OS they instead indicate USB FW:V1.04. If your POD remains at USB FW:V0.00 after connecting to the computer it means that it is not recognized by the OS, which can be due to one of 3 problems: 1) the driver on the computer is not installed correctly. In this case completely uninstall the driver and install again, avoiding that the computer security system blocks the complete installation of the driver. 2) the port used on the PC to connect to the POD is not suitable such as a USB 3.0 or it is a USB HUB. 3) the USB port of the POD and perhaps also its USB Controller chip are damaged not allowing any connection. I recommend trying to connect the POD to another computer even without installing anything on it. If at the time of connection there is no reaction at all from the computer (which normally should at least detect the presence of unknown hardware connected) it means that the USB port of the POD is dead, and the only solution would be to replace it. _______________________________________________________________________________________________________________________________________________________________________ All about POD HD500/X help and useful tips Quote Link to comment Share on other sites More sharing options...
herbalwharf9261 Posted February 5 Author Share Posted February 5 Ok, voy a probar el 3 consejo, los primeros dos ya los probe anteriormente. Ojala que no sea la pedalera. Gracias de nuevo Quote Link to comment Share on other sites More sharing options...
