SoCalDave Posted February 1, 2025 Share Posted February 1, 2025 I'm using my Pod Go to record guitar into Logic Pro. Logic sees the Pod and everything is fine except for the recording level. I have to manually add gain to each track I record, even though the volume pedal and knob are maxed out. I can't find any settings to adjust a default or global volume setting. It's better when I turn up the drive for the particular amp, but I mainly record super clean guitars, maxing out the volume with the drive set as low as possible. Any ideas? Quote Link to comment Share on other sites More sharing options...
silverhead Posted February 1, 2025 Share Posted February 1, 2025 On a PC I would ask if you’re using the Lin6 ASIO driver in your DAW settings. I don’t know if that actually applies on a MAC (core audio??) but check it out. Also I presume you are using the POD Go as the audio interface? The default audio level over USB is adequate. I don’t think there’s any reason other than DAW settings for what you describe. Quote Link to comment Share on other sites More sharing options...
