chris_one Posted 21 hours ago Share Posted 21 hours ago Hi, as much as I love my HX Stomp I'm currently stuck with the following issue (or challenge): I got 3 snapshots, the usual clean, breakup, heavy crunch I got two external footswitches, which do not have led-rings. FS-4 turns a solo boost on and off (i.e. stomp mode-ing an EQ) and FS-5 turns a chorus on and off. This works basically great, but in the heat of the moment I'm not always sure what is on and what is off. Question: Can I configure the existing led rings on FS 1-3 to change color according to the state of the boost and/or the chorus? It seems like a waste to just have them shine white if their respective snapshot is on... Thanks a bunch! chris Quote Link to comment Share on other sites More sharing options...
chris_one Posted 17 hours ago Author Share Posted 17 hours ago To phrase it differently: I want to be in snapshot mode, but want the LEDs color to be determined by whether the stomp-block is active. This sounds so doable to me, so I really hope this is somehow possible... Quote Link to comment Share on other sites More sharing options...
Edward357Johnson Posted 4 hours ago Share Posted 4 hours ago Hi Chris, You can configure the LED rings on FS 1-3 to change color according to the state of the boost and chorus. In STOMP Mode, use CommandCenter to assign the footswitches and set the LED colors. Customize the settings by pressing Knob 6 and then Knob 5 to adjust the LED colors. Quote Link to comment Share on other sites More sharing options...
