Signal path
arcanjil
I connect my W10 laptop to the PG and run the editor to create and edit presets. I also use the USB port to run mp3' backing tracks from my laptop.
My question is, what is the signal path of that?  Does it follow the same path as my guitar or does tr go straight to the power amp (I use 4CM)?
If not, is there a way to set it so it goes straight to the power amp?
By default the computer’s signal comes into the POD Go on the USB 1/2 channels and is sent directly to the PG’s outputs with no processing. If you want to process it you can set the Input block of the PG preset to USB 5/6. (See manual section on USB Audio for details.)
