johnnypro Posted February 23, 2025 Share Posted February 23, 2025 I decided I wanted to use one of my Variax guitars for some recording. The 600 I knew had some problems with being intermittent, but the 300 always worked be4. I pulled out the 600 and got sound. But it died when I turned the selector switch. So I dug out my 300, which I hadn't played in a while, put in a fresh 9v battery and it worked for about 5 seconds and died. They should work for a bit on a 9v, correct? I don't have a battery pack for the 300. The 300 always worked for me before on 9v. I'm gonna try and open them tomorrow to see if I can get them working. Any pointers?? Oh, both "chirp" if I disconnect the battery while plugged into the amp. Thanx!!! JP Quote Link to comment Share on other sites More sharing options...
psarkissian Posted February 24, 2025 Share Posted February 24, 2025 Take them to a Line 6 authorized service center in your area. They can check it out and have experience with Line 6 products. Self repair is not recommended and is ill advised. https://line6.com/find/service_center/ Quote Link to comment Share on other sites More sharing options...
johnnypro Posted March 1, 2025 Author Share Posted March 1, 2025 Any other suggestions before I part them out? Some one must have taken these apart and fixed them? Quote Link to comment Share on other sites More sharing options...
psarkissian Posted March 3, 2025 Share Posted March 3, 2025 Loose internal connection would be the first suspect. Line 6 authorized service center is the best option to narrow it down. They will have the experience with the product. Quote Link to comment Share on other sites More sharing options...
