Adam_Dreyer Posted March 17, 2025 Share Posted March 17, 2025 I recently picked up a Friedman Pink Taco V2 combo and, separately, a Friedman IR-D preamp pedal. The Pink Taco is a one channel 20 watt valve amp with an FX loop. The IR-D is a preamp pedal which also includes an FX loop. I want to use the HX Effects to switch between the 'internal' preamp of the amplifier and the 'external' preamp pedal, to create 2 channels which I can toggle between. I'd also like the option to apply distortion/compression before the preamp and time-based effects after the preamp. I think I need some sort of variation on the 4 cable method, but I'm stumped! Does anyone have any experience with this or know how to do it? Many thanks, Adam Quote Link to comment Share on other sites More sharing options...
rd2rk Posted March 17, 2025 Share Posted March 17, 2025 Using both FX Loops, put the IR-D in one and the Pink Taco in the other. Create an A/B Split with one FX Loop in each path. Assign a FS or Snapshot to control the Split. Your LEFT/MONO out goes to the PT's RETURN. You can set it up for either/or, AND/OR combine the two using the ROUT TO parameter (Knob 1) and use Snapshots to control the specifics. See page 38 of the manual. Quote Link to comment Share on other sites More sharing options...
