Helix won't connect to HX edit
kevin11007
Hi , Need help, Helix won't connect to HX edit, swapped USB leads into rear port on pc, all latest drivers and software installed, USB port not broken. Tried on laptop also, still won't connect.
I have had issues with USB devices and cables in the past believe it or not. I can't remember which USB 2.0 B cable I have but I know for a fact it did not play well with the Helix and then I found the one it came with and have never had any issues. I would try a different USB cable unless you're already using the one L6 provided.
