FX Loop
Sqawk
The ‘space’ that is important is the amount of DSP a preset uses. Even with the current constraint of 4 flex blocks it is quite easy to run out of DSP capacity/space. The visual graphic display is not as important in terms of adding blocks.
I know there is a hacked preset floating around that has 5 flex blocks but I don’t know if the FX Loop was removed to create it. It works as long as you use the less DSP hungry FX blocks. You can probably find that preset with a little googling.
Thanks, that is a consideration I had not considered.
