Mobi Posted April 1, 2025 Share Posted April 1, 2025 Hi All, I currently use my Helix Floor only for FX, connected to my dual rectifier head and 4x12 cab using the 4 cable method. However for home practice, I want to use my helix floor connected directly to my 2x12 cab and using helix amp models. Is t hat possible? How do I create a new prest for this and how do I connecte my helix to my cab directly? Quote Link to comment Share on other sites More sharing options...
rd2rk Posted April 1, 2025 Share Posted April 1, 2025 Just replace the FX Loop Block with the Helix Amp Block. You will need a power amp of some sort between Helix and the 2x12 cab. Any pedalboard power amp will do. 1 Quote Link to comment Share on other sites More sharing options...
Mobi Posted April 7, 2025 Author Share Posted April 7, 2025 Ok thanks for the reply. Quote Link to comment Share on other sites More sharing options...
BryanEdwards Posted April 10, 2025 Share Posted April 10, 2025 On 4/1/2025 at 9:59 PM, rd2rk said: Just replace the FX Loop Block with the Helix Amp Block. You will need a power amp of some sort between Helix and the 2x12 cab. Any pedalboard power amp will do. Yes, you can use the 4-cable method in one preset and switch to a different setup using Helix amp models and go direct in another. It’s like having the freedom to switch playstyles at the poker table—versatile and strategic. Just like navigating changing laws in the casino world, especially around https://zarubezhnye-kazino.com/zapret-na-azartnye-igry/ adapting your rig setup is all about knowing your options. Thanks for the advice. Quote Link to comment Share on other sites More sharing options...
