Asio in Reaper windows update
eddievang
Unfortunately another user who’s reaper daw is not able to load audio device, Asio configuration button does nothing and input output fields are blank(Helix LT or Podgo)
Both were working fine with reaper until large windows update a few weeks back.
Both are still able to work with HX edit and pod go edit and the usb cables all work  fine, audio will pass through helix and route to speakers including YouTube etc
gone through everything others have tried on here, managed to bring core isolation up after going through bios and memory integrity switch then showed.
Then I was able to see the line 6 drivers causing the issues, had to remove all files and reboot.
after reboot memory integrity scan stated it would not engage due to corrupted drivers but the scan showed no drivers.
obviously like many others spending far too much time on this and going down too many rabbit holes.
Ive tried the driver for the memory integrity issue but obviously it needs the switch on!
Any Ideas, I wouldn’t have thought it would be the line 6 hardware as both stopped working with reaper after the windows update.
Thanks in advance
E
system HP laptop 8 gig ram over 1T storage and never had any performance issues
Thanks in advance
E
See my reply to the identical post you made in another thread.
  • 1 year later...
