Question About Command Centre
wingz
In command Centre can you rename the same  foot switch in a different snapshot from say (snap shot 1 ) a (fs1)  named (boost ) (key a)
to in  (snap shot 2) - (fs1) renamed  (multi)  (key b)
I know you can reassign  the type of command  function but I do not see how to rename it, when its in different snap shot and it has a different functioning command.
You can't assign a FS to a different FUNCTION in different Snapshots, only different VALUES related to a function. Likewise, a named FS, even if you change the FUNCTION (which changes it in ALL Snapshots), retains the NAME you've assigned it across Snapshots.
IOW - If in SS1, FS1 is assigned to NOTE and a VALUE of D4, then in SS2 it will be NOTE but with the default VALUE of C3 until you change the VALUE.
If you change the FUNCTION to MIDI CC in either SS, that change will apply to all other Snapshots. Regardless, the NAME will remain the same in ALL Snapshots.
thank you for your fast reply.
fyi, when I referred  to function. I was meaning value. I just couldnt think of how to ask my question at the time.
cheers!
