wingz Posted April 18, 2025 Share Posted April 18, 2025 In command Centre can you rename the same foot switch in a different snapshot from say (snap shot 1 ) a (fs1) named (boost ) (key a) to in (snap shot 2) - (fs1) renamed (multi) (key b) I know you can reassign the type of command function but I do not see how to rename it, when its in different snap shot and it has a different functioning command. Quote Link to comment Share on other sites More sharing options...
rd2rk Posted April 18, 2025 Share Posted April 18, 2025 You can't assign a FS to a different FUNCTION in different Snapshots, only different VALUES related to a function. Likewise, a named FS, even if you change the FUNCTION (which changes it in ALL Snapshots), retains the NAME you've assigned it across Snapshots. IOW - If in SS1, FS1 is assigned to NOTE and a VALUE of D4, then in SS2 it will be NOTE but with the default VALUE of C3 until you change the VALUE. If you change the FUNCTION to MIDI CC in either SS, that change will apply to all other Snapshots. Regardless, the NAME will remain the same in ALL Snapshots. 1 Quote Link to comment Share on other sites More sharing options...
wingz Posted April 19, 2025 Author Share Posted April 19, 2025 thank you for your fast reply. fyi, when I referred to function. I was meaning value. I just couldnt think of how to ask my question at the time. cheers! Quote Link to comment Share on other sites More sharing options...
