cbalexander Posted May 16, 2025 Share Posted May 16, 2025 I've been using the HX Effects in 4CM for years. It has suddenly developed a problem where the FX loop on path A is extremely quiet, nearly muted and very distorted. The last couple of times this happened, rebooting the unit worked, but now that's not fixing it. I've tried multiple patches, even a fresh patch using nothing but the FX loop effects block. If I turn the FX loop block off, the signal is fine...if I move the effect block to path B the signal is fine. Any advice is appreciated...hoping it's not a defect in my unit. Quote Link to comment Share on other sites More sharing options...
rd2rk Posted May 17, 2025 Share Posted May 17, 2025 Very strange. I'm going to go with try re-installing the FW (BACK UP FIRST!). If that doesn't work, attach a sample preset that shows this behavior. Maybe there's something that you've started doing in all of your presets? It's a long shot, but if re-installing the FW doesn't fix it your only other option is a support ticket. 1 Quote Link to comment Share on other sites More sharing options...
