Holly666 Posted May 22 Share Posted May 22 Hi, I’ve had my POD for a while but I’ll hopefully be using it on stage next Friday, except I can’t figure out how to quickly change between tones like you would with a normal effects pedal. For example, we’re doing a song where I need to switch between a clean reverb tone and a heavy metal tone quickly, how do you do this with the POD HD? If not, I’ll have to use one of my effects pedals which aren’t as good sounding :/ any help is appreciated! Quote Link to comment Share on other sites More sharing options...
silverhead Posted May 22 Share Posted May 22 Since you’re asking this question I presume you have the POD HD Desktop (kidney bean shaped) model, not one of the other POD HD models that have built-in footswitch controllers. To use your feet rather than your hands to change presets with the Desktop model you will need a compatible footboard controller. The options are listed in an Appendix of the manual (link attached). https://line6.com/data/6/0a06434dc1125085c5933f8db/application/pdf/POD HD Advanced Guide v2.10 - English ( Rev A ).pdf Quote Link to comment Share on other sites More sharing options...
Holly666 Posted May 22 Author Share Posted May 22 On 5/22/2025 at 9:18 PM, silverhead said: Since you’re asking this question I presume you have the POD HD Desktop (kidney bean shaped) model, not one of the other POD HD models that have built-in footswitch controllers. To use your feet rather than your hands to change presets with the Desktop model you will need a compatible footboard controller. The options are listed in an Appendix of the manual (link attached). https://line6.com/data/6/0a06434dc1125085c5933f8db/application/pdf/POD HD Advanced Guide v2.10 - English ( Rev A ).pdf Thanks for your help! Quote Link to comment Share on other sites More sharing options...
