shawndeveau Posted June 8 Share Posted June 8 I have programmed MIDI CC commands to some of the footswitches to Play/Stop my DAW. Everything works perfectly, except every once in a while, the Helix display changes to the Command Center when I press one of the switches.... Seems to be random.... Any idea what's causing this and/or how to stop it from happening? Thanks, Shawn Quote Link to comment Share on other sites More sharing options...
rd2rk Posted June 8 Share Posted June 8 Global Settings>Footswitches>Stomp Select. Set that to TOUCH. If that doesn't fix it you may have to perform a Factory Reset. Don't forget to BACK UP first! 2 Quote Link to comment Share on other sites More sharing options...
shawndeveau Posted June 9 Author Share Posted June 9 Was already set to touch, so I did a factory reset by holding switches 10+11, but the issue is still there. There are a bunch of different factory resets but it isn't clear which one I should try.... Quote Link to comment Share on other sites More sharing options...
shawndeveau Posted June 9 Author Share Posted June 9 It might be my imagination, but I think the problem goes away when I'm wearing shoes.... Pressing the switches with my hands or stockinged feet makes the problem worse.... Changing Global Settings>Footswitches>Stomp Select to PRESS seems to have resolved the issue. I can live without TOUCH if that's the case.... 1 1 Quote Link to comment Share on other sites More sharing options...
