sofiaglez Posted August 20 Share Posted August 20 I'm trying to use my Line 6 Catalyst 60 as an audio interface. I have all the drivers installed, and I've successfully used it for recording in the past because it gets the job done. However, I'm having an issue: I can hear both the processed audio and the "clean" audio. In other words, when I plug the amp into my computer and run the guitar through some plugins, I hear the processed signal, but I also hear the clean signal coming from the amp, as if it weren’t being used only as an interface. I'm doing this with the power knob set to "MUTE". Quote Link to comment Share on other sites More sharing options...
rd2rk Posted August 20 Share Posted August 20 To hear ONLY the audio from the plugin you need to turn OFF the Cat's Channel Volume. Quote Link to comment Share on other sites More sharing options...
