Expression Pedal Curve setting
itoshin37
Hi, I would like to request the addition of a new feature called “EXP2 Curve” to the global settings. The reason is as follows.
I use Pod Go for two ways. The first is when I connect an external expression pedal to EXP2 for volume control and use the built-in pedal for wah. The second is to use simply Pod Go only, in which case I do not use wah. This varies depending on the gig.
My external expression pedal is an Ernie Ball VP Junior. This pedal is technically a volume pedal, but it can be used as an expression pedal by connecting a cable to the OUT jack.
The issue is that this pedal uses an “A-curve pot (logarithmic),” so if the volume curve setting on the effect edit page is set to logarithmic, the volume changes become too sudden (logarithmic x logarithmic!). Setting the volume curve to linear resolves the issue, but when not using an external pedal this is undesirable as the built-in volume pedal's curve is “B-curve (linear)”
If there were a function to specify the volume curve of an external expression pedal in the global settings, the issue would be completely resolved. There is a function called EXP1/2 Polarity, and this new EXP2 Curve function can be placed near the Polarity function.
Adding this function would expand the choices for external pedals.
thanks.
