jmillion Posted 19 hours ago Share Posted 19 hours ago Hi all. I have the itch to run stereo again and I’m hitting a mental block on designing a preset that can be stereo for both XLR and 1/4 (without IRs/sims). Does anyone have a template or preset they can share? Quote Link to comment Share on other sites More sharing options...
rd2rk Posted 17 hours ago Share Posted 17 hours ago Looks like you did a cut/paste from an app with a black background - nothing is visible! The bit that was readable in the notification email said: Hi all. I have the itch to run stereo again and I’m hitting a mental block on designing a preset that can be stereo for both XLR and 1/4 (without IRs/. Create your split using a stereo block - I usually use a GAIN Block. The split itself results in two stereo paths. If you want IRs on the XLR path (usual practice for FOH sends), use the DUAL IR Block and Pan the IRs to taste. To complete the split to stereo 1/4" and Stereo XLR outputs, pull the MERGE Block down and select the output types on the Output Block. Refer to the manual if you don't know how to do these things. 1 Quote Link to comment Share on other sites More sharing options...
