Daaniml Posted November 26 Share Posted November 26 Hi! Today is my first day with the Helix Stadium XL and everything was fine untill i load some IR´s to try them. When I select one inside of the cab block, my screen fades out into the "Line6 Helix Stadium xl" and I cant do anything I dont know if its any bug or whatever, but i tried everything to do a factory reset and i cant find a way to do it manually with some button combination (I already read the way to restore it but obviously i cant because do anything with the screen like that! jeje) Can anyone help me plis? Thanks a lot and sorry for my english!! Quote Link to comment Share on other sites More sharing options...
silverhead Posted Thursday at 01:31 AM Share Posted Thursday at 01:31 AM Have you restarted the Helix Stadium? if it restarts correctly proceed to the following paragraph. If not, open a support ticket. Once you can see the main screen, In the top left corner you will see a menu button, an icon with several horizontal bars. One of the selections from the menu is Helix Stadium Maintenance. One of the maintenance options (top right area of the display) is Restore Factory Defaults. Quote Link to comment Share on other sites More sharing options...
Daaniml Posted Thursday at 02:50 AM Author Share Posted Thursday at 02:50 AM Yes, the problem is that when i restart the unit that screen that i posted on the photo is what I see always, it doesnt change to the principal Quote Link to comment Share on other sites More sharing options...
silverhead Posted Thursday at 03:53 AM Share Posted Thursday at 03:53 AM Try holding down footswitches 6 and 12 when powering up. Then select Restore Factory Defaults. When complete, choose the Shutdown option. Quote Link to comment Share on other sites More sharing options...
Daaniml Posted Thursday at 06:13 AM Author Share Posted Thursday at 06:13 AM WoW!! Thanks a lot!! It works, yeahh Quote Link to comment Share on other sites More sharing options...
silverhead Posted Thursday at 12:29 PM Share Posted Thursday at 12:29 PM Glad you got it working. On 11/26/2025 at 8:31 PM, silverhead said: … Once you can see the main screen, In the top left corner you will see a menu button, an icon with several horizontal bars. One of the selections from the menu is Helix Stadium Maintenance. … I want to correct some inaccurate information I provided earlier. The Helix StadiumMaintenance screen is not available from the Menu icon. It is only available through a startup sequence. You can hold down either FS 6 and 12 (as I suggested) or the Home and Song buttons (as described in the manual) when powering up. 1 1 Quote Link to comment Share on other sites More sharing options...
mike-w Posted 8 hours ago Share Posted 8 hours ago The manual isn't clear on a reinstall. It only tells you to use Helix Stadium Edit, and that is only for updates. I just reinstalled my firmware by using Line 6 Central. 1 Quote Link to comment Share on other sites More sharing options...
