lwilliams Posted 9 hours ago Share Posted 9 hours ago This seems to be a problem with the OG Helix and the new Stadium. I can't find a way to get rid of that really thin tinny high end. If I cut the "amp" treble back and the high of the Global EQ, I can get rid of it, but then there is almost no treble at all. I am sure a lot of you know what I am talking about. I am using mostly Fender Teles and Strats. When I tried the OG Helix, it was going into a PowerCab Plus. Now I have the new Fender FR-12. Has anyone found a way to solve this? If so, how is it done? Quote Link to comment Share on other sites More sharing options...
waymda Posted 4 hours ago Share Posted 4 hours ago I run strats and teles with no issues. I use various microphones and alter their position to adjust the tone, and experiment with cabs. It is normal to roll off the top end with global EQ, or on a desk if going direct, to remove high end info with a LPF, and low end with a HPF, as an amp in the room does not reproduce this. Where you set these is a matter of taste. I also use a tight Q notch to dip around the 3-4k mark, and a small mids notched boost to sit in the mix. What might seem extreme, may in fact be normal. When I ran a powercab+ I also reduced the gain of the tweeter, as I found it harsh. Here's an old discussion about this, but some recent videos about the stadium have suggested it removes some of the problematic frequencies already. Quote Link to comment Share on other sites More sharing options...
