bearfacedcow Posted January 4 Share Posted January 4 Not sure if this has been reported, but I discovered two snapshot issues in the 1.2 release. 1. if I have the Global settings to automatically add a stomp when adding in effect, and I delete the assigned stomp, snapshot bypass for that effect does not work when I change snapshots. IOW, it will not change bypass settings for that snapshot. If I turn off the automatic assign in Global settings, bypass settings will then work. 2. I had Teemah assigned to a stomp and when I changed snapshots, when bypassed, It would briefly light up and you would hear a momentary effect and then cut out. However, this will not occur when it is not assigned to a stomp. My workaround for the first issue he is keeping and automatic assign off. With the second one I’m just activating distortion units by changing snapshots and not assigning them to stomps. jord Quote Link to comment Share on other sites More sharing options...
silverhead Posted January 4 Share Posted January 4 Open a support ticket to report these issues. There are some known bugs regarding Snapshot behaviours that will be addressed in a future firmware release. Quote Link to comment Share on other sites More sharing options...
bearfacedcow Posted January 5 Author Share Posted January 5 Will do... found another one as well jord 1 Quote Link to comment Share on other sites More sharing options...
