Stadium App problems
bbehrens
I have run into many different issues from connectivity, Sound, Parameter assignment, and Impulse Response switching in Presets. I have hardly run the gamut of capabilities of this fantastic device yet. BUT, I have found (so far) that programming a preset exclusively on the Stadium XL floor unit alone has produced significantly more consistent and expected results.
I don't know about anyone else here, but I have had (almost - holding cards here) - NO PROBLEMS creating presets on the Stadium as compared to the Stadium App that I am running on Windows 11 (Latest update as of this writing).
If you run into any issues, carefully build the preset from scratch using only the interface on the Stadium itself and see if you have nearly as many issues.
I would be interested to now of issues with the Stadium App OR on the Stadium floor unit alone. I think that doing a little of BOTH is just asking for trouble until Line 6 gets the newborn issues under control.
Try using only the Stadium interface. You'll still have to import stuff using command center on the App - but that should not present any problems.
bbehrens, I have been creating the presets on the Stadium XL device itself for the same reason.  I use the Stadium App if I want to fine tune the color, move presets to reorder, copy, make templates, etc.
In my creation environment I have the Stadium XL on a platform next to my computer.  So far, with the Stadium App closed, I've not had an issue with preset creation connected to Wi-Fi and connected via USB to my DAW or for playback/play along with music files or videos.  I disconnect the usb-c cable when I launch the Stadium App to fine tune and test the global EQ on/off as well as the learning process I am going through with Showcase.  Fun fact, I thought I was a novice with Showcase but it turns out I am a pre-novice ... I was going to say sub-novice but it didn't have the same ring ;-)
jpd
I have way too many issues with the Stadium App to mention. I would rather use the touch screen on unit because not only is it reliable, but faster too. On top of its bugs, the app is nothing short of a UX & RSI nightmare.
jord
