acarrasquillo77 Posted Wednesday at 01:30 PM Share Posted Wednesday at 01:30 PM Been having an issue creating a preset and i saved the first snapshot when im going to create another snapshot and save it the settings of the other snapshot doesn’t save even though i have the snapshots control on in Every parameter amd discard edits are off any one with this issue? Quote Link to comment Share on other sites More sharing options...
jpdennis Posted Wednesday at 03:52 PM Share Posted Wednesday at 03:52 PM On 1/14/2026 at 5:30 AM, acarrasquillo77 said: Been having an issue creating a preset and i saved the first snapshot when im going to create another snapshot and save it the settings of the other snapshot doesn’t save even though i have the snapshots control on in Every parameter amd discard edits are off any one with this issue? Are you saving the preset each time you create a snapshot as well? Are you using the app to create the snapshots or the stadium device? Thanks for any reply, jpd Quote Link to comment Share on other sites More sharing options...
acarrasquillo77 Posted Wednesday at 07:27 PM Author Share Posted Wednesday at 07:27 PM Im using both at the same time any way to fix this?? Quote Link to comment Share on other sites More sharing options...
jpdennis Posted Thursday at 04:38 PM Share Posted Thursday at 04:38 PM On 1/14/2026 at 11:27 AM, acarrasquillo77 said: Im using both at the same time any way to fix this?? acarrasquillo77, From the current readings in this forum there is an issue with the app that is being looked into by Line 6 support. Most are just using the Stadium XL device, as I am. I create the snapshot, save it, then move to the next snapshot I want to create, save, etc. It has worked for me so far. For any fine tuning once the snapshots are saved and working as expected I will use the app only for minor adjustments. I save the snapshot in the app then, after saving each snapshot, I use the mouse to click on the output block, select snapshot 1, and save the preset one last time. This method, while slightly tedious, has worked 99% of the time for me. jpd Quote Link to comment Share on other sites More sharing options...
johnekis Posted yesterday at 06:33 PM Share Posted yesterday at 06:33 PM I'm having the exact same issue, I believe. Doesn't matter if I use the device itself or the desktop app. I can make changes to individual parameters, and even if I save them one by one, they don't actually save. Whatever I've turned on (or off) will essentially change each snapshot. So, it's basically useless at this point. Very frustrating as I can't do anything with this thing. Quote Link to comment Share on other sites More sharing options...
