boynigel Posted January 22 Share Posted January 22 I just noticed in a pic of the back panel that the stadium lacks the Amp Out jack that my OG Floor model has. Did they ditch this functionality with the Stadium, or is it something that can be assigned to one of the other outputs? I often use my OG as a dedicated, effects-only floor board, and to do channel switching on my PT15IR. I'm hoping the Stadium will allow me to do this as i wouldn't want to have to add a midi device such as Suhr's microMIDI Control, or the like. not to mention it would make upgrading to Stadium $120 more expensive, and it'd be another device on the floor. Quote Link to comment Share on other sites More sharing options...
silverhead Posted January 22 Share Posted January 22 You can do this in Command Centre. There’s also a flag for that in Showcase. You can also assign a physical Output (e.g. 1/4”) to Instrument level. Or, place a Send block anywhere in the signal chain and adjust its Level to suit. Quote Link to comment Share on other sites More sharing options...
nobod999 Posted January 22 Share Posted January 22 You have to configure the control jacks: https://manuals.line6.com/en/helix-stadium/live/global-settings#[mediaInline]-Global-Settings->-Switches/Pedals Determines whether each Control jack (A~D) is an expression pedal input, external footswitch input, external drum trigger input, or an external amp remote switch output. 2 Quote Link to comment Share on other sites More sharing options...
boynigel Posted January 22 Author Share Posted January 22 still doable with snapshots? i never assign a dedicated footswitch to the amp as it's done solely within snapshots. Quote Link to comment Share on other sites More sharing options...
