Default output set to Multi even without Powercab and DT25/50?
erodrigues
It appears that all presets in Helix default to output to Multi which includes supporting Powercab and DT25/50, the issue i found is that when i set to XLR or 1/4" only, the sounds changes dramatically.
If I am not using a Powercab and DT25/50, why would this happen?
What is the best practice to use if the Helix is to be connected either to a mix console and/or a external amp?
Sorry if this is a dumb question :( I am honestly puzzled.
Hope someone can help
I've had mine for 10 yrs and never noticed that, so I just tested it.
I don't hear it. Nor was there a difference when I had a Powercab switching from Multi to Digital.
Not that it should matter, but what is the specific signal chain - post Helix devices - that you are using?
My XLRs go to a Scarlett interface and studio monitors, my 1/4" to the Power Amp In of my Catalyst.
Same - no diffference.
Can't see why it would happen even if you were using the L6 Link output. They're independent outputs and the changes to DT or Powercab settings have no relevance to the XLR or 1/4 inch outs.
