Jack wiring of external amp in order to accept Helix channel change command
boynigel
Yes, i know it's in the manual but i'm at work and my new computer refuses to open or download the manual.  i'm going to be talking with an amp builder and he'll need this info to ensure my LT can switch the amp's channels.
something to the effect of, "hot to sleeve" ...or something like that from what i remember.
Extracted from the LT manual v. 3.80 - Page 9
“Alternatively, this jack can be connected to your traditional guitar amp to switch its channels or turn its reverb on and off. Use a TRS cable for dual operation (1=tip, 2=ring).”
Also page 69 Global Settings
EXP 2/EXT AMP
Determines whether the rear panel EXP 2/EXT AMP jack acts as an additional expression pedal input (EXP 2) or as a dual amp control output for switching channels on external guitar amplifiers (EXT AMP).”
Hope this helps/makes sense.
EDIT: darn, I just repeated the same info from when you asked this back in 2022.
