Helix restart whit taptempo and wha problem whit expression pedal
spearfishing
I have a Helix Stadium Floor, not the XL version. When I use the Tap Tempo footswitch, the snapshot names appear on the screen. Helix restarts. I even made a video, but I don't know where to send it. I'm having trouble because after spending €1,848, I'm afraid to use Helix live.
I also wrote in a previous post that when the WHA is turned on by a footswitch, the expression pedal then controls it. But if you set the setting to turn it on with pedal movement, it doesn't work.
This is an officially known issue and is supposed to be fixed with a new firmware update.
Support recommends:
Install firmware version 1.2.1.
If you already have it installed, a factory reset might help.
After the factory reset, the problem only occurred sporadically for me.
We have to wait for a new firmware update.
