Tap tempo not working anymore?
fenno52
Tap tempo not working anymore? Used several times with external tap tampo last few gigs (the walrus audio canvas clock). Now this internal tap tempo doesn't work anymore. It is not updating the bpm when tapping FS 12. Help?
I think I have found the cause of the problem. I reconnected the Walrus Audio Canvas and turned on the receive clock, so the BPM is being driven externally again. Now I first removed the MIDI cable from the Helix Stadium, and after that, the BPM tap (footswitch 12 Stadium) worked again. I probably turned off the Stadium last time with the MIDI cable from the external clock still plugged in, causing it to lock. The tap tempo is working again now!
