CC Toggle help in Command Center- Snapshot bypass for CC toggle?
Sgwoodley
Hey all!
Longtime lurker here finally finding an issue i'm stumped on regarding my HX Stomp XL.
I am attempting to control my Eventide H9 and Chase Bliss Brothers AM via MIDI in the effects loop of the Stomp XL. I'm trying to carry over my workflow from my Quad Cortex into this current rig. I am offsetting wet effects and drives to the Eventide H9 / Brothers AM to save DSP for amp sims, poly capo, room reverb, eq etc.
In Command Center, Footswitches 1-3 will be used to send CC Toggle values to the "ModEchoVerb" algorithm in the H9 to turn on/off chorus, delay, and reverb respectively. Footswitch 4-6 select between snapshots 1-3 to reflect gain staging. In these snapshots, PC instant messages are sent to the Brothers AM to recall presets.
Normally, if footswitches 1-3 were set to control blocks within the Stomp itself, I'd be able to disable snapshot bypass and control them independently of the snapshot I select for gain staging. However, it seems that "CC toggle" commands on Footswitches 1-3 don't have that option anywhere I can find within the Stomp. Is there some advanced MIDI wizardry, secret setting, etc that I'm missing to be able to carry over my CC Toggle selections between snapshots?
TLDR: Is it possible to disable snapshot bypass of CC toggle commands assigned per footswitch, rather than instant commands?
Thanks for any help or info!
No. When you load the HX preset, any and all CC Toggling messages assigned to footswitches will send the MIN value assigned in the saved/default SS.
If you use a FS to send the MAX value, the MIN value will send on the next SS change.
I've always wished that behavior was optional (DO NOT send FS Toggling CCs on SS Change), but it is what it is.
  • 1 month later...
