MZ66669 Posted March 27 Share Posted March 27 Hello, my guitar has passive pickups (Lundgren M7, 1 volume knob) but in my daw (Logic X) the DI Signal (Input 7) is approx. 10 db too loud. Is there any way to adjust this level? Thanks Florian Quote Link to comment Share on other sites More sharing options...
silverhead Posted March 28 Share Posted March 28 I don’t think you can adjust the level inside the Stadium after the signal hits the Guitar Input jack. The DI signal gets tapped immediately at the input point. I believe even the Pad setting in the Input block must affect the signal after it enters the Stadium device, and hence after the DI tap. I expect you will need to attenuate the signal either before it hits the Stadium or after it leaves Stadium, i.e. in your DAW. 1 Quote Link to comment Share on other sites More sharing options...
MZ66669 Posted March 28 Author Share Posted March 28 I understand, thanks for your reply. I figured a workaround with di box to mic input, but I think Line6 should make adjustable DI Input levels in future update. BR Quote Link to comment Share on other sites More sharing options...
