blank000 Posted April 14 Share Posted April 14 "Upgraded" to W11. And Reaper refuses to see Helix. Helix it self is connected to PC just fine, HX Edit works fine, playing Audio from PC through Helix works fine. But when I try to select Helix as device in Reaper this is what I get: This is in options, ASIO driver is there, but inputs and outputs are empty. When I select Direct sound, I'm still getting sound through Helix! Latest Windows, latest Reaper, latest HX Edit and accompanied drivers. I found an old Reddit thread where removing Helix as default device is suggested. Tried it. Didn't work. Reinstalled drivers, didn't work. Anything to be done? Thank in advance! Quote Link to comment Share on other sites More sharing options...
rd2rk Posted April 14 Share Posted April 14 IDK how you reinstalled the drivers, but if you re-install the latest version of HX Edit (download it - v3.82), that is the correct way. You MAY have to uninstall all L6 drivers, reboot and try again if re-installing HX Edit alone fails to solve the problem. Sometimes having multiple old versions installed can cause issues. Quote Link to comment Share on other sites More sharing options...
blank000 Posted April 14 Author Share Posted April 14 On 4/14/2026 at 10:44 PM, rd2rk said: if you re-install the latest version of HX Edit (download it - v3.82), that is the correct way. Did exactly that, didn't help. On 4/14/2026 at 10:44 PM, rd2rk said: You MAY have to uninstall all L6 drivers, reboot and try again if re-installing HX Edit alone fails to solve the problem. Just tried it. Uninstalled L6 drivers and HX Edit, reboot, reinstall. No change, the exact same behavior. On 4/14/2026 at 10:44 PM, rd2rk said: Sometimes having multiple old versions installed can cause issues. Brand new installation of everything, no old version in sight. Quote Link to comment Share on other sites More sharing options...
rd2rk Posted April 14 Share Posted April 14 I have Reaper and Helix installed on two different W11 machines, one upgraded from W10, no problems. What processor is in your computer? Mine are both i7, different gens (7 & 11). I've read of people with other processors having problems. Assuming you've got an Intel processor, try installing one of the other FREE DAWs such as LIVE Intro, see if you still have problems. Maybe Reaper somehow got corrupted? Quote Link to comment Share on other sites More sharing options...
blank000 Posted April 15 Author Share Posted April 15 On 4/15/2026 at 1:17 AM, rd2rk said: try installing one of the other FREE DAWs such as LIVE Intro, see if you still have problems. I tried with Cakewalk Sonar, and even though I have no idea what I'm doing in that thing, it looks like everything works. Detected Helix right away, recording on 1-2 records wet, on 7-8 dry, opens Helix ASIO settings... On 4/15/2026 at 1:17 AM, rd2rk said: Maybe Reaper somehow got corrupted? I wrote "upgraded" to W11, but I didn't actually upgrade from 10, it was format C: kinda thing, everything is brand new. But it's obviously a Reaper thing, not Windows or Helix thing. I'll switch to Reaper forum. Thank you for your help! Quote Link to comment Share on other sites More sharing options...
blank000 Posted April 15 Author Share Posted April 15 Well, apparently installing Sonar also fixed Reaper :D Quote Link to comment Share on other sites More sharing options...
rd2rk Posted April 15 Share Posted April 15 Computers. Can't live with them, hitting them with a stick is satisfying but expensive. 1 Quote Link to comment Share on other sites More sharing options...
Rikkiff Posted Wednesday at 08:47 PM Share Posted Wednesday at 08:47 PM Hi blank000, I am having the exact same issue as you were having months back. Also tried re-installing drivers to no avail. Is the solution really to install Sonar (which I assume refers to Cakewalk Sonar?) or is there an more elegant solution? :) Thanks! Quote Link to comment Share on other sites More sharing options...
