EX2 into Stadium XL behavior
AZGuitar
The EX2 expression pedal is acting as if the polarity setting is reversed in Global settings.
I've used a Boss FV500L forever with the OG and first run SXL with polarity reversed with no issues. Crazy thing is I now notice that regardless of the polarity settings, the Boss is behaving as programmed and the EX2 is reversed. Could be my settings but I don't think so.
Can someone test their polarity setting? Thanks!
I couldn't get my FV500L pedals to work with the Stadium. 100% in the middle of the travel, with 0% at both ends, and reversed polarity when I experimented. Usual solutions didn't work. EV30 worked OK so I didn't pursue the problem.
I plugged in the FV500L. Setting the Maximum Volume to Max did correct the range problem as you said. I obviously didn't persevere very much when I tried it! I was able to correct the polarity via Settings > Global Settings > Switches/Pedals > swipe left twice to Flip A (tip) Polarity > set to On. This worked OK with the TS cable plugged into A/B.
Note that the setting you need is the Flip A (tip) polarity, NOT the Flip EXP 1/2 Polarity. That applies to the built-in pedal, and will reverse its polarity as you describe.
The EV30 has a polarity switch, so I had previously used that instead of delving into Stadium settings. Leaving the polarity flip set to On for the FV500L in the Stadium settings, I was able to switch the EV30 polarity switch back to Normal, so that both pedals now work.
"Note that the setting you need is the Flip A (tip) polarity, NOT the Flip EXP 1/2 Polarity."
That's it! Thank you @gbr13697 for your help. I did not think to page further over where I had originally set that parameter for the FV.
