The sounds of my Pod Go presets (1.40.1) are a bit "saturated" on my new Pod Go Wireless (2.50).
filiptibo
Hello, I have a Line 6 POD Go multi-effects unit (firmware: 1.40.1 (build bc2dac9e)) and a newer one, a POD Go Wireless (firmware: 2.50 (build 6e984472)). I transferred the presets from my old unit and installed them on my POD Go Wireless. However, I noticed that the main output of the POD Go Wireless is slightly distorted compared to the sounds on my original POD Go. Why is that? And how can I get my original sounds back without this slight distortion? Thank you!
There was a hardware fault in the very early Pod GO units off the manufacturing line. It affected resistance in the input circuitry. It was resolved fairy quickly but it's possible that your older Pod Go unit has this fault and the later one does not. That could explain the difference. To be sure open a support ticket. If your old model is flawed Line 6 will repair it for free.
Having said that, the repair would make the older unit sound like the newer one, which is not what you want. Get advice from Line 6 while your support ticket is open.
And, of course, the issue could be something else. But start with this possibility.
