mickscrill Posted July 2 Share Posted July 2 Hi there, I don't seem to have (Remember) option in displays preferences on helix stadium. On boot up it keeps booting to one particular preset and not last used which is what I want any ideas thanks Ronny IMG_8910.heic Quote Link to comment Share on other sites More sharing options...
mickscrill Posted July 2 Author Share Posted July 2 I'm on firmware 1.3.2 Quote Link to comment Share on other sites More sharing options...
silverhead Posted July 2 Share Posted July 2 I believe that when Stadium starts up it momentarily loads the preset that was active at shutdown. However, it then consults Showcase and loads the preset, if any, specified in the active Song. To ensure that Showcase does not change the preset, load a Song that does not specify a preset before shutdown. 1 Quote Link to comment Share on other sites More sharing options...
mickscrill Posted July 2 Author Share Posted July 2 Correct :) Thank you Quote Link to comment Share on other sites More sharing options...
mickscrill Posted July 2 Author Share Posted July 2 Would be good to be able disable that function when working on presets and when having to reboot because dropped Wifi. Quote Link to comment Share on other sites More sharing options...
silverhead Posted July 2 Share Posted July 2 Since you replied “Correct” I assume that you’ve set the Showcase/Song appropriately before shutdown, and that your Stadium is now starting up as you desire. I guess you can consider that to be disabling the function. It should start up as desired every time now until you activate a differently configured Song before shutting down. Quote Link to comment Share on other sites More sharing options...
