littlespaceman Posted July 5 Share Posted July 5 Getting a bit frustrated by how complex it seems to be to CLEAR a F/S stomp assignment. The quick action methods all seem to be geared towards assigning and not clearing - for example tap the icon on the Home screen and you get a pop-up to do lots of things, including assign a F/S, but nothing there to clear it if one is assigned already. If I go to Command Centre, and use the Clear/Reset All function, for some reason it doesn't actually clear Stomp assignments, it only clears the other things I may have assigned, like a Hot Key or Midi Message. The method of touch/holding a footswitch to bring up the Assign pop-up is all well and good, as that does offer a 'Clear Stomp' option, but it means your hands are flying around all over the place - hardly a slick way of operating. And lastly, you can clear a stomp by selecting the Bypass/Control menu option, then tap each block that has a F/S assigned, then dial the 'Switch' rotary dial to the left until it says 'None' - but this is a crazy long-winded way of doing it. Am I missing something - is there simple and quick way to clear a stomp assignment? Quote Link to comment Share on other sites More sharing options...
MojoAxe Posted July 5 Share Posted July 5 There's not an obvious way to view nor clear assignments that I'm aware of. What I usually do to clear an assignment is to tap the block, copy it, delete the block, then paste it back in to the same location. This will purge an assignments that were associated with the block. Something else that has annoyed me is that apparently when I saved several blocks to my Favorites folder, those blocks had assignments which got carried over to the saved Favorite, so now when I add that block to a new preset, the assignments get carried over to the new preset, which is not something I want to have happen. What I need to do is go through all the blocks in my Favorites list, figure out which ones have assignments embedded within them, then delete those Favorites and add them back with the assignments cleared. Apparently the Helix Edit (OG) has a menu to view and edit assignments. I imagine that Stadium will have that feature whenever they get time to add it in. Quote Link to comment Share on other sites More sharing options...
littlespaceman Posted July 6 Author Share Posted July 6 Wow, that's a long-winded way of having to do things. And it seems like quite an oversight not to have a basic function like this included from the get-go... Quote Link to comment Share on other sites More sharing options...
