geepeeaay Posted July 8 Share Posted July 8 Hi I’ve discovered the Helix usb connection from my iPad I can’t work out how to control the volume of the iPad when going through the Helix floor The iPad volume is bypassed and seems to only be controlled by the main knob on the Helix How do I control the iPad volume please? Aim To be able to adjust volume of backing tracks sent from the iPad Set up: iPad lightening out via adapter (2 x usb + 1 lightening in) usb cable in to Helix usb Helix set up as a mixer, 4 channels (2 x guitars, 1 aux, 1 mic) Helix outs set up as digital as I’m using L6 link from Helix to Soundscape Lt2m - Lt2 Cheers Quote Link to comment Share on other sites More sharing options...
datacommando Posted July 9 Share Posted July 9 On 7/8/2026 at 5:26 PM, geepeeaay said: Hi I’ve discovered the Helix usb connection from my iPad I can’t work out how to control the volume of the iPad when going through the Helix floor The iPad volume is bypassed and seems to only be controlled by the main knob on the Helix How do I control the iPad volume please? Aim To be able to adjust volume of backing tracks sent from the iPad Set up: iPad lightening out via adapter (2 x usb + 1 lightening in) usb cable in to Helix usb Helix set up as a mixer, 4 channels (2 x guitars, 1 aux, 1 mic) Helix outs set up as digital as I’m using L6 link from Helix to Soundscape Lt2m - Lt2 Cheers Hi See the section of the Helix Owner’s Manual regarding USB Audio on page 73. Your playback from the iPad and the Camera Connection Kit is via USB 1&2 through the Helix “Multi IN”, additional controls can be found on page 68, Global Settings In/Out - USB1&2 Destination, and USB1&2 Trim. https://line6.com/data/6/0a00051afda2673ccc1cc8e68/application/pdf/Helix 3.80 Owner's Manual - English .pdf Hope this helps/makes sense. 2 Quote Link to comment Share on other sites More sharing options...
geepeeaay Posted July 10 Author Share Posted July 10 On 7/9/2026 at 1:04 AM, datacommando said: Hi See the section of the Helix Owner’s Manual regarding USB Audio on page 73. Your playback from the iPad and the Camera Connection Kit is via USB 1&2 through the Helix “Multi IN”, additional controls can be found on page 68, Global Settings In/Out - USB1&2 Destination, and USB1&2 Trim. https://line6.com/data/6/0a00051afda2673ccc1cc8e68/application/pdf/Helix 3.80 Owner's Manual - English .pdf Hope this helps/makes sense. Hi Thanks for the link All worked out great Just had to adjust the USB trim 1&2 to the required level … Thanks again 1 Quote Link to comment Share on other sites More sharing options...
