Why can't I get 6 effects to the 6 footswitches in Stomp Mode ?
Jupiter567
Hi all - so, using Go Edit, only 5 effects icons show at the top. Extra effects pedal icons can't be added - so how can I get 6 effects assigned to the 6 pedals in Stomp mode. (I have changed it to 6 footswitch setting in Global settings).
I have watched many YT vids and read the manual but I can't see where it can be done. I haven't seen a video yet where 6 effects are assigned.
I'll be playing in an old school country band, so I'm looking for Delay, Tremolo, Chorus, OD, Comp and clean boost for solos. Those 6 would do me the whole set. Why do I change Global settings to 6 footswitches when I can only get 5 effects assigned ?
Any help gratefully appreciated. Thanks
On 7/12/2026 at 8:53 PM, Jupiter567 said:
... using Go Edit, only 5 effects icons show at the top. Extra effects pedal icons can't be added ..
While there are only 5 icons that say "FX" the bypass state of the other icons can also be assigned to a footswitch. For instance, you can change the Wah FX to be turned on/off using a footswitch rather than the Exp Toe switch. You can even assign block parameter values to a footswitch. For instance, you can assign the amp's Gain parameter to toggle between two values.
See the Pod Go Edit manual for details.
