gcwebbyuk Posted July 14 Share Posted July 14 I have a Pod Go that is updated to the latest firmware (2.50) and using the latest WIndows drivers (2.00.0.0). I have two Windows 11 devices (laptop and PC) if I play audio from either device via USB to the Pod Go (so I can play over the top of it) I get an annoying pop/crackle in the left channel. This at random intervals and doesnt seem to be associated with what is playing at all. I have tried on both devices, tried different USB ports on the two devices, tried different USB cables, even returned the Pod Go for a replacement and that device has the same issue. I contacted support who advised a couple of settings that made no difference. The PC audio format is set at 24 bit, 48000 Hz (Studio Quality) but I have tried various other formats and all continued to pop. I have made sure spatial audio is disabled, and ensured that exclusive mode has been disabled. I have changed the ASIO buffer size in the Pod Go control panel. It's preventing me from using headphones to play over PC audio. I can play through my monitors and then play the PC audio from a seperate set of speakers (with no issues). Any ideas? Thanks! Quote Link to comment Share on other sites More sharing options...
silverhead Posted July 14 Share Posted July 14 On 7/14/2026 at 5:33 AM, gcwebbyuk said: ... It's preventing me from using headphones to play over PC audio. ... Have you tested your headphones? Quote Link to comment Share on other sites More sharing options...
gcwebbyuk Posted July 18 Author Share Posted July 18 On 7/14/2026 at 1:35 PM, silverhead said: Have you tested your headphones? Yes they are ok. The sound is heard via monitors and also if I connect a Katana to the amp out port on the Pod Go so it’s definitely coming from there. Quote Link to comment Share on other sites More sharing options...
