philthethrill21 Posted July 27 Share Posted July 27 Hello. I have a weird question for setting up 4cm in my pedal chain. I want to run my HX One after my drives (used for delay and modulation mostly) and before my Strymon Deco and Flint. And then I would like to have it ran again using the 4cm at the end in case I wish to use the looper. Is that possible and would I need to change my cabling anytime I wanted to do it this way? I want to run everything in front of the amp btw. Sorry about the confusion. Im probably making a mountain out of a mole hill. For visual: Regular connection - Tuner>OD>Fuzz>HX1>Deco>Flint>Amp 4CM - Tuner>OD>Fuzz>HX1>Deco>Flint>Back to HX1?> Amp? Any suggestions would be appreciated. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
bobritsky Posted August 4 Share Posted August 4 Hi. I think that's pretty straightforward 4cm wiring. I use it with the AMP EMULATOR - Atomic Amps Firebox - but you can use any amp modelling unit - Tonex, Strymon Iridium etc. This is a signal chain: (lets enumerate HX ONE top side connection sockets left to right 1-2-3-4) Guitar --> Drive -> HX ONE 4 , HX ONE 3 -> OUT of the amp modeller, HX ONE 2 -> IN of the any effects you want to keep AFTER the amp, like Delay, Reverb etc., HX ONE 1 -> IN of the amp modeler. And final signal is coming from OUT of those Delay/Reverb which come last. Set HX ONE to INSERT mode and play with PRE/POST setting for each preset you use on HX ONE: basically it moves HX ONE before the amp modeler (for filters, drives, compressors, synths etc.) or after amp modeler (for delays, reverbs etc.) So in your case - you don't use amp modeler and have Strymon Deco/Flint instead. Your signal path will look like this: Guitar ->Drive -> HX ONE 4, HX ONE 3 -> OUT of Flint or Deco (the last one), HX ONE 2 -> input of the amp, HX ONE 1 -> IN of Flint or Deco (the first one) Tell me if it help. Quote Link to comment Share on other sites More sharing options...
