candeCARTAGO Posted August 19 Share Posted August 19 I would like to know if it's possible to set up the LFS2 pedal to be able to program 4 channels? Quote Link to comment Share on other sites More sharing options...
rd2rk Posted August 19 Share Posted August 19 No. You need a cheap 4 button MIDI pedal such as Hotone Ampero Control (what I use) or MVAVE Chocolate. 1 Quote Link to comment Share on other sites More sharing options...
rd2rk Posted August 20 Share Posted August 20 I see that you posted and deleted two questions, so if you're still wondering, the devices I mentioned will allow you to select any of the 12 presets, plus control any of the FX. I'm not familiar with the specific 2-button switch you referred to, but normally they only control preset up/down. Quote Link to comment Share on other sites More sharing options...
candeCARTAGO Posted August 21 Author Share Posted August 21 The doubt I have is about connectivity... that is, the LFS2 pedal that comes with the amp I plug into the amp’s FOOTSWITCH input... and I can switch between 2 channels... with the devices you mention... how do I connect them to the amp? Will it recognize them? The amp has a CATALYST EDIT app where you can change a lot of things, but I’m not sure if I can configure either of the 2 devices you mention from there. Quote Link to comment Share on other sites More sharing options...
rd2rk Posted August 21 Share Posted August 21 As is often said, the devil is in the details, and you didn't specify the model of your Catalyst. Since the connections are not obvious, I'll assume that you have a Catalyst 60, which does not have a MIDI DIN Port. To use MIDI you'll either need a HOST (a computer, iPhone or iPad), a MIDI controller that doubles as a HOST. or a HOST "box". Amazon.com: M-VAVE Chocolate Plus MIDI Footswitch Controller Pedal, 4 Buttons, USB Compatible, APP Control, Portable : Musical Instruments I've never used this, so read everything you can find about it. AFAICT, you should be able to simply connect a USB-B to USB-C cable from your Cat60 to the Chocolate+ and use the wireless app to program it. If you choose to go this way, buy it from a store with a no-questions-asked return policy. It's non-host version gets good reviews on The Gear Page. If you have an iPhone/iPad (idk about androids) you can connect directly and the iThingy will serve as a host. I recommend getting a powered hub instead of direct connect, else usable time will be limited by the battery in your iThingy. I use this with my iPad: Amazon.com: Anker USB C Hub, 5-in-1 USBC to HDMI Splitter with 4K Display | 85W Max PD, 1 Powered USB-C 5Gbps & 2 Powered USB-A 3.0 5Gbps Data Ports, for MacBook Pro, MacBook Air, Dell and More (Black) : Electronics You can also connect a standard (non host) MIDI controller using one of these: Amazon.com: CME H2MIDI Pro Compact USB Host MIDI Interface | Router, Filter, Mapper, 32-Bit Processor, Dual Power Mode, Minimal Size, For Guitarists & Producer : Musical Instruments There are other products at various prices in all of the above categories. I suggest that you do your due diligence before deciding which way to go. 1 Quote Link to comment Share on other sites More sharing options...
candeCARTAGO Posted August 22 Author Share Posted August 22 Sorry, my amp is a CX 100 Quote Link to comment Share on other sites More sharing options...
rd2rk Posted August 22 Share Posted August 22 Then it has MIDI DIN ports and all you need is a controller with DIN ports and a MIDI DIN cable of an appropriate length. If you choose to go wireless then you'll need a wireless to MIDI DIN adapter. I don't recommend wireless. I find it to be undependable on a good day. YMMV. Catalyst Edit continues to work with a USB cable to whatever computer/iThingy that you're currently using. 1 Quote Link to comment Share on other sites More sharing options...
