davidc2478 Posted August 24 Share Posted August 24 Hey guys! I got a Dunlop DVP5 (8) to use as my volume pedal. I plugged in a TRS cable from EXP3 into EXP. It's recognized but when moving the pedal forward I hit 100% volume about halfway. If I continue to move my toe forward the volume begins to cycle back down to 0. I want it to be a single 0-100 sweep from heel to toe. Any ideas what is wrong? Quote Link to comment Share on other sites More sharing options...
yalyari Posted August 24 Share Posted August 24 1. Open Dunlop, flip the internal switch to reverse foot/heel polarity. 2. Use TS, not TRS cable. (Or TRS Y splitter cable depending on your usage. Just make sure Dunlop side is TS.) 3. Invert Tip/Ring polairity on Helix. Quote Link to comment Share on other sites More sharing options...
davidc2478 Posted August 24 Author Share Posted August 24 That did it! Crazy, I thought the blue switch just reversed setting. Like Heel would be 100 and Toe 0. I also did have to invert the setting for EXP3 that I'm using. Cool, thank you! Quote Link to comment Share on other sites More sharing options...
