sozorox Posted September 8 Share Posted September 8 Hello all, thank you in advance for any help. I have a line 6 Helix LT. I would like to run the left output to my 5150iii combo, and the right output to a evh hypersonic FRFR cabinet, using an amp and cab Sim. I've tried following some YouTube videos, but when it comes to panning my signal, something isn't working right. I know it can't be that difficult. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
rd2rk Posted September 9 Share Posted September 9 On 9/8/2026 at 2:23 PM, sozorox said: Hello all, thank you in advance for any help. I have a line 6 Helix LT. I would like to run the left output to my 5150iii combo, and the right output to a evh hypersonic FRFR cabinet, using an amp and cab Sim. I've tried following some YouTube videos, but when it comes to panning my signal, something isn't working right. I know it can't be that difficult. Thanks in advance. Attached are 2 example presets. Example 1 is the usual way that it's done. Guitar>Helix INPUT Helix SEND 1>5150 INPUT 5150 SEND>Helix RETURN 1 Helix 1/4" LEFT MONO OUT>5150 RETURN Helix XLR LEFT MONO OUT>EVH Hypersonic INPUT If you want to use a Helix amp in addition or in place of the 5150's Preamp you can either place the Helix amp adjacent to the FX Loop with both Bypass assigned to a FS with FX Loop SAVED ON/Helix amp OFF (FS toggles 5150/Helix) as in example 1 or place the Helix amp on the Path 2B Split in front of the Cab as in the second example. There's lots of ways to do this, but in your configuration I think that using 1/4" for your 5150 and XLR for the FRFR would work best. sozorox1.hlx sozorox2.hlx 2 Quote Link to comment Share on other sites More sharing options...
sozorox Posted September 10 Author Share Posted September 10 Thanks, I will try that! Quote Link to comment Share on other sites More sharing options...
