Possible solution for Helix Stadium Edit Wi-Fi disconnections
DaniGP
wanted to share what has worked for me, in case it helps anyone experiencing constant disconnections between Helix Stadium and Stadium Edit on Windows.
In my case, when I connected the Helix Stadium directly to my home Wi-Fi, Stadium Edit kept disconnecting constantly, sometimes approximately every 30 seconds. I also tried entering the IP address manually, but the problem continued.
What has worked for me is creating a Wi-Fi hotspot directly from my Windows PC and connecting the Helix Stadium to that network instead of my home router.
This is what I did:
In Windows, I went to Settings → Network & Internet → Mobile Hotspot.
I enabled the hotspot.
Windows created a Wi-Fi network with its own name and password.
On the Helix Stadium, I searched for that Wi-Fi network and connected to it.
Stadium Edit then detected my Helix Stadium automatically and connected without me even having to enter the IP address manually.
So basically, the Stadium is communicating directly with the PC through the Wi-Fi network created by Windows, instead of going through my home router.
So far, the connection has been completely stable. I tested it for around 40 minutes without a single disconnection, whereas with my normal home Wi-Fi it could disconnect every 30 seconds.
I can't say this will work for everyone, and I don't know exactly what is causing the original Wi-Fi issue, but I wanted to share it because it has worked for me so far.
I'll update this post if I experience any further disconnections after longer testing.
  • 1 month later...
DaniGP! Good to hear it stayed connected for four hours. I included your hotspot tip in a Wi-Fi troubleshooting article on my site, with credit and a link back to this thread. There are a few other checks in there too, for anyone still having trouble:
https://helixguitar.com/articles/helix-stadium-edit-wifi-disconnecting
Has it stayed stable for you since?
I solved the problem in a different fashion.
I created a VLAN for the Line 6 traffic.  I enabled the 2.4gHz radio only.  I enabled client isolation.  I gave it a /29 IP.
With this I get automatic connections to the editor as soon as the Hellx boots.  The connection is rock solid for hours with no glitches.
