atomheart411 Posted October 27 Share Posted October 27 I tried on the software editor and on the unit itself and nothing happens. Quote Link to comment Share on other sites More sharing options...
datacommando Posted October 30 Share Posted October 30 On 10/27/2026 at 8:48 PM, atomheart411 said: I tried on the software editor and on the unit itself and nothing happens. Hi, To use Reset Options: Power off the Helix Hold the desired button combination Power on the Helix Release the button combination HX Effects Button Combination Description Holding FS3 + MODE Will clear all Presets and IRs Holding FS4+FS5 Will reset Global Settings Holding FS5+FS6 Will reset Presets only Holding FS6+TAP Will Perform factory restore (reset, Globals, IRs, and Presets) Holding the right arrow ">" Will put the unit in a fail safe update mode. Use this when the HX Effects is in an un-recoverable state FROM THE HX EDIT PILOTS GUIDE 3.8 Restore Factory Settings This button at the bottom left of the Preferences window resets all items in all three tabs of the Preferences window back to the initial factory default settings. NOTE: Your Helix or HX device also includes several additional settings within its Global Settings screens (as well as its own Restore options) This Restore Factory Settings button restores only the settings shown within the HX Edit application’s Preferences window. If you follow these instructions, and the reset options still fail, then you should raise a ticket with Customer Service. Hope this helps/makes sense. Quote Link to comment Share on other sites More sharing options...
