Snapshot Issue - Swapping effect order
suspendedinlight
Guessing there's a conflict in the software, but hoping to be able to fix this.  Hardware is HX Stomp.
1. I have two effects that use the same footswitch button to bypass both. They are set up so I can turn Effect A off, while simultaneously turning Effect B on with the same motion. That functionality works fine.
2. I have these effects set up in Snapshot 2.  When I save this in HX Edit - it works fine in initial tests.  When I move from Snapshot 1 to Snapshot 2, Effect A is on, and Effect B is off. I can play within this snapshot alternating between the two effects.
For reference - Footswitch 1 is Snapshot next, Footswtich 2 is Snapshot Previous, Footswitch 3 is the bypass for both effects.
3. The problem:  While everything works fine at first, after a few rotations through the snapshots, Effect B is now on when I switch to Snapshot 2, and Effect B is off (should be the opposite).  Something is making the HX lose this setting.  For reference - Effect B is further left in the Bloc chain than A, but I can't really swap them and keep the same sound.
Set FS1 to PRESS/HOLD in all 3 Snapshots.
In SS1, make FS1 PRESS = SS2.
In SS2, make FS1 PRESS = SS1.
In BOTH snapshots 1/2 make FS1 HOLD = SS3.
In SS3 set FS1 PRESS = SS1; FS1 HOLD = SS2.
One switch controls it all in all 3 snapshots.
DON"T use a separate switch to perform the toggle within the snapshots.
SS1 A=ON;B=OFF
SS2 A=OFF;B=ON
SS3 BOTH OFF
Example attached.
FS 3way Toggle.hlx
