stephen41diaz Posted 8 hours ago Share Posted 8 hours ago Hey everyone, I’ve been using my AMPLIFi mostly at home for practicing over backing tracks streamed via Bluetooth, and I’m having a hard time getting a consistent mix between the music and my guitar signal. When I switch between clean and high-gain presets in the AMPLIFi Remote app, the guitar volume jumps dramatically compared to the backing track, forcing me to constantly tweak the main blend knob or my phone volume. How do you usually level your patches—do you rely on the preset’s main output/amp channel volume, use a compressor/EQ block at the end of the chain, or set a specific baseline level across all saved tones? Would love to hear how you keep your presets balanced! Quote Link to comment Share on other sites More sharing options...
silverhead Posted 4 hours ago Share Posted 4 hours ago On 11/19/2026 at 4:01 AM, stephen41diaz said: …., or set a specific baseline level across all saved tones? … This is what I do. It can be a tedious chore initially because you have to individually edit each preset to match output levels. Some people use a level metering tool but I find my ears are my best tool. You’ve already mentioned the common adjustments for this: channel volume, Level parameter in the Output block, an EQ block with every parameter set to neutral except the Level parameter. These are preset level controls that do not affect the tone. Avoid using tone-affecting controls like the amp’s Drive/Gain or Master setting, or a separate Gain block early in the signal chain where it can affect the tone of downstream FX like Dist. After the initial leveling exercise you just need to check that for each new preset you save. Quote Link to comment Share on other sites More sharing options...
