chiolas Posted May 14, 2014 Share Posted May 14, 2014 Hi guys, I really really like this preset, I really can imagine a lot of cool stuff to do with it, but I can't change the key of it. Instead of G#m I'd like to have this done in another key, but I tried to change the key on the first effect of the picture but it stays always in G#m. Can someone help me please ??? Quote Link to comment Share on other sites More sharing options...
radatats Posted May 14, 2014 Share Posted May 14, 2014 where is the patch? If you share it I will take a look for you... Quote Link to comment Share on other sites More sharing options...
bjnette Posted May 14, 2014 Share Posted May 14, 2014 Hit save after you change, then save again for destination. Quote Link to comment Share on other sites More sharing options...
chiolas Posted May 15, 2014 Author Share Posted May 15, 2014 where is the patch? If you share it I will take a look for you... radatats: how can I send it to you ??? Quote Link to comment Share on other sites More sharing options...
radatats Posted May 15, 2014 Share Posted May 15, 2014 radatats: how can I send it to you ??? just upload it to Customtone and copy/paste the link here. Quote Link to comment Share on other sites More sharing options...
chiolas Posted May 15, 2014 Author Share Posted May 15, 2014 just upload it to Customtone and copy/paste the link here. after a whole afternoon rehearsing (with my old rig) here's the link for the preset radatats: http://line6.com/customtone/tone/323136/ Thank you Quote Link to comment Share on other sites More sharing options...
radatats Posted May 15, 2014 Share Posted May 15, 2014 OK so after playing around with it for a bit, it is a 500X patch but it loads in my 500 with HD Edit by drag and drop. I think the patch may be corrupted somehow. I checked it out as best I can and I don't see the expression pedals linked anywhere. However, moving exp 1 changes the key through the full range audibly without any visible changes to the patrameters in HD Edit. I can change the key in the Smart Harmony but audibly there is no difference. There is the slightest change to predalay in the Echo too. If i move exp 2 the timing of the Stereo Delay changes momentarily but goes back to its original setting and there is no link on the Controllers Tab. I would suggest writing down all the settings for each effect and then reconstructing the patch from scratch. That way you may be able to get the results you want. I think linking the expression pedal to the Key and sweeping from A to G# gives you a lot of options. It doesn't look like the Scale matters as it just seems to drone anyways without reacting to the notes you actually play. Good luck and let us know how it works out! 1 Quote Link to comment Share on other sites More sharing options...
