JeffersteinVS Posted May 30, 2014 Share Posted May 30, 2014 What vocal compression ratio do you recommend live with the dream stage setup? i know gain before feedback is a issue and wondering what people are using. thanks in advance Quote Link to comment Share on other sites More sharing options...
dboomer Posted May 30, 2014 Share Posted May 30, 2014 It's another one of those "It all depends" answers ;) What exactly do you hope to gain? There is both compression ratio and threshold to consider. So you could use a very low ratio (say 1.4:1) but set the threshold 15-20 dB low Or you could set the ratio higher (4:1) but set the threshold at 0 or above. As you noted, if you are feedback challenged you probably will have very little room to operate without causing yourself a lot of problems. Also remember that a compressor effectively turns up all the unwanted junk and leakage that your mic picks up. So my best suggestion not knowing anything about the particulars of your situation would be (assuming a rock band performance) to leave if off or set the threshold very high (0 or above) with a ratio of 4 or less. If you can "hear" much compression I'd say you are running too much. Now if I was doing speech at a school or a house of worship then I could use a bit more to achieve the "announcer" kind of voice. Quote Link to comment Share on other sites More sharing options...
